Indicators Stopped Working
8 replies to this topic
#1 oltonlad
oltonlad
  • 2,401 posts
Posted 16 February 2013 - 02:44 PM
hi all, i took the mini out this morning, everything was fine, then the indicators stopped working, i've checked the fuses, checked for a loose connection etc, the hazards have stopped working as well.
if i run a wire from the fusebox to the flasher unit then they work ok (as do the hazards)
so obviously there is a problem with the live feed to the flasher unit but i'm no electrician and need some help.
the car is a 1993 mini.
any ideas guys?
cheers.
#2 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 16 February 2013 - 02:45 PM
Did you check the in-line fuses too?
#3 oltonlad
oltonlad
  • 2,401 posts
Posted 16 February 2013 - 02:47 PM
i could see 2 inline fuses under the steering column, i think that 1 is for the stereo because when i took the fuse out the stereo went off, i'm not sure what the other one is for though, is there a seperate inline fuse for the indicators/hazards then?
#4 MRA
MRA
  • 7,607 posts
Posted 16 February 2013 - 03:00 PM
Indictor fuse is on the bulkhead in the engine bay.
#5 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,154 posts
  • Name: Sean
Posted 16 February 2013 - 03:02 PM
If the hazzards have stopped working then it could be the hazzard warning switch, when that fails it can screw up the indicators.
#6 oltonlad
oltonlad
  • 2,401 posts
Posted 16 February 2013 - 03:15 PM
i've tried changing the hazard switch, its still the same, i'll look in the engine bay for this other in line fuse....cheers.
#7 MRA
MRA
  • 7,607 posts
Posted 16 February 2013 - 03:27 PM
Inline fuse ?? no its in the fuse box.... one of four fuses, also chec the wires too/from the fuse box
#8 oltonlad
oltonlad
  • 2,401 posts
Posted 16 February 2013 - 03:35 PM
it was a dodgy connection behind the air filter......................thanks guys... ;D
#9 reallybig
reallybig
  • 616 posts
Posted 17 February 2013 - 09:40 AM
yeah thats where mine buggers up, stupid crappy inline fuses.
installing a fusebox there in a few weeks, everysingle bump in the road makes those fuses giggle loose
