Drive Shaft/diff Output Seal - Help!
3 replies to this topic
#1 MiniAustin
MiniAustin
    Starting My Mini Up
  • 4 posts
Posted 16 February 2013 - 05:30 PM
Hi All,
I am currently learning to drive (test booked, so wish me luck!) and have purchased a 1985 Austin Mini with an MG Metro 1275 engine.
The driveshafts were leaking oil quite bad and I therefore decided to replace the seals...
I've come to realise by now that if there's anything wrong with my car - let it be, or open up a can of worms!
Anyway, I split the top ball joint earlier and managed to remove the driveshat from the pot joint, I have also removed the pot itslef, revealing the culprit seal...
Supprisingly easy i thought...until i tried to remove the old seal which seems to have bonded itself to the diff side cover...doh!
After a few hours of picking and levering, I am now left with half a worn seal that seems almost impossible to remove(see pics attached)...
Does the old seal have a metal backing, which I need to pry off?
Any ideas?
Much Appreciated
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 16 February 2013 - 05:36 PM
The metal bit you've exposed is part of the seal ( it's the core of the seal giving it its shape )
By now I assume you have drained the oil, therefore I would remove the cover completely which will give you much better access to remove, and replace, the seal and also a chance to check the bush in the cover. More often than not diff seal failure is due to the bush wearing and allowing the pot to move up and down.
#3 MiniAustin
MiniAustin
    Starting My Mini Up
  • 4 posts
Posted 16 February 2013 - 08:54 PM
Great, cheers for that. Was hoping not to remove the side cover as it seems like a tricky job
#4 Willthewelder
Willthewelder
  • Validating
  • 161 posts
  • Local Club: Colchester Mini Club
Posted 17 February 2013 - 08:19 AM
Use a small say 2mm drill bit and wind a self tapper in each side will get it out.
