Can I Convert A Leaded Head To Unleaded?
6 replies to this topic
#1 jackx998
jackx998
  • 264 posts
Posted 17 February 2013 - 12:03 AM
As the title states really, I tried searching but my Google fu has failed.
Thanks in advance
Jack.
#2 Tupers
Tupers
  • 4,173 posts
Posted 17 February 2013 - 12:06 AM
It needs to be done by a machine shop, basically they machine out the valve seats in the iron head and insert a harder steel one.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 17 February 2013 - 12:39 AM
What engine are we talking about Jack you have 998 in your user name so is it that size? Firefox a while back posted a list of engine numbers as below suitable to run unleaded.
99HF15, 99HF32, 99HG30, 99HG31, 99HG32, 99HG33, 99HG34, 99HG39, 99H/D81P, 99H/E20, 99H/E21, 99H/E22, 99H/F16.
#4 jackx998
jackx998
  • 264 posts
Posted 17 February 2013 - 11:09 AM
Hi kernow, I'm running an MG 1275 engine bored to 1330, my first mini was a 998 :). I had seen a nice stage 3 head on the cheap but the only problem is that it's a leaded head, I've had a little delve into dome previous threads which covered the problems, think ill just get my current head worked on as it'll more than likely be cheaper than buying this new head and getting it converted to unleaded.
Cheers!
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 February 2013 - 11:56 AM
Par engines/head centre (or what ever they are called) did my last head for £50
they are down next to roselyn coaches
#6 jackx998
jackx998
  • 264 posts
Posted 17 February 2013 - 03:15 PM
Was that for the conversion bungle? Don't suppose you know the address do you?
Cheers for the info bud.
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 February 2013 - 03:59 PM
i removed the head and gave it to them bare, they then fitted the hardened seats
http://www.qualitycy...co.uk/about.php
