Subframe Thread Sizes Please For Pre 76.
Posted 19 February 2013 - 10:57 PM
I need the front twin tower bolt hole thread sizes...
Front subframe thread size for captive nut next to top arm pin (goes through pin plate)...
Rear subframe rear trunnion bolt thread size....
& i already know that the rear radius arm mounting brackets to subframe thread sizes are 5/16th's unf but thought i'd mention it so maybe a member of staff can pin this topic for other people to see after comments from knowledgable tmf folk (cooperman were are youuuuu ).
Thank you
Posted 20 February 2013 - 11:53 AM
Posted 20 February 2013 - 04:08 PM
Posted 21 February 2013 - 09:46 AM
Posted 21 February 2013 - 01:07 PM
Think its a bolt welded into the subframe from production.
Cliff
Posted 22 February 2013 - 02:04 AM
Posted 22 February 2013 - 02:55 AM
If its the one that has the bush slip over it then its 7/16"unf, im sure of it, however measure the diameter of the thread....
Yeah the one that the rear trunnion & bushes slides on,it beside the rear cone commpress hole.
The xtuds closest to the camera in this shot pointing outward: http://www.minispare.../Rear.aspx|Back
Edited by rally515, 22 February 2013 - 02:58 AM.
Posted 22 February 2013 - 10:35 PM
Posted 23 February 2013 - 01:06 PM
Posted 23 February 2013 - 02:45 PM
A vernier caliper is a useful tool and you can often find the electronic type cheaply, just perfect for situations like this, but my thinking was that not everyone has one yet, many people might never even have had the need to buy a steel rule, but everyone has spanners.
Edited by tiger99, 23 February 2013 - 02:45 PM.
Posted 23 February 2013 - 05:07 PM
Yes, I don't expect it to be tight, but the next size down will should go on, which would tell something. But will the plain part of the pin not be very close to 7/16" diameter? I would guess that the clearance would only be about 10 thou on that part. Decent spanners are quite closely toleranced.
Ok so tried a 7/16 spanner & it went round partially.
Caliper gauge is up the swanny
Posted 23 February 2013 - 05:32 PM
Posted 23 February 2013 - 05:41 PM
Posted 23 February 2013 - 05:43 PM
Posted 23 February 2013 - 06:26 PM
