Quick Question About Polishing Rocker Cover's
16 replies to this topic
#1 kappa
kappa
  • 1,301 posts
Posted 20 February 2013 - 10:39 PM
Hi all,
As per title what is the best way of polishing a Mg Metro Turbo Rocker Cover, the one with fins and a center oil filler cap?
All help is really appreciated
Bobby
#2 iMurray
iMurray
    Mild Cheddar
  • 1,396 posts
Posted 20 February 2013 - 10:43 PM
clean... dry, autoglym metal polish... or whatever polish you want... small clean rag or leather... apply small amount of metal polish to all of rocker cover, a thin even smear in circular motion... make sure you get right between the fins... take the cap off too to get right o the edges... once its all "hazed" buff it off with clean leahter or rag...
jobs a good'un go kiss your missus
#3 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Clean and then autosol the **** out of it :P
You can get drill attachments that will speed up the process.
#4 iMurray
iMurray
    Mild Cheddar
  • 1,396 posts
got there first noah ;)
#5 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 20 February 2013 - 10:46 PM
You could paint it black and just polish the highlights
#6 Noah
Noah
  • 4,136 posts
Circular motions on a rag are more likely to inflict scratches than anything. You should only use Microfibre Towels, and only in straight lines.
#7 kappa
kappa
  • 1,301 posts
Posted 20 February 2013 - 10:47 PM
Cheers guys for the help.
iMurray if its a good'un, i will be kissing the missus, as she will be doing the polishing for me, ;D
Bobby
#8 iMurray
iMurray
    Mild Cheddar
  • 1,396 posts
Posted 20 February 2013 - 10:50 PM
oh, when i say rag i only EVER EVER MEAN microfibre... good for everything those things :)no need for straight lines if its a clean rag and a clean surface then you'll be fine. plus most of the lines down the grooves will be straight so you wont have to much scrubby scrubby
#9 Noah
Noah
  • 4,136 posts
Posted 20 February 2013 - 10:52 PM
Ian.....
When polishing and leaving a haze you lift off old dirt and corrosion, so wiping it off in circles and rubbing it into the surface in circles defeats the point of polishing it....
#10 iMurray
iMurray
    Mild Cheddar
  • 1,396 posts
Posted 20 February 2013 - 11:10 PM
didnt say wipe it off in circular motions... i said put it on with circular motions... difference! difference i say! plus microfibres move rubbish and grit to the back of the pile as they clean...
#11 Midas Mk1
Midas Mk1
  • 5,787 posts
  • Local Club: S.U.N.M.C
Posted 20 February 2013 - 11:22 PM
Drill attachment mop and compound, autosol just doesnt give the same effect.
(got an actual fish eye for my iphone now, not a **** app haha)
Bad photo ( from 3 years ago) but you get the idea after 5 mins on it, gone for a different look now on mine though, different box but still SHINY :D :thumbsup:
Edited by Midas Mk1, 20 February 2013 - 11:23 PM.
#12 Noah
Noah
  • 4,136 posts
Posted 20 February 2013 - 11:32 PM
Did you take a picture in 8-Bit or did you upload it to photobucket, both are known to result in an Image quality like that! ;D
#13 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 21 February 2013 - 12:02 AM
Noah, is there anything you don't know everything about ? .... Mwahaha
Andrew.
#14 kappa
kappa
  • 1,301 posts
Posted 21 February 2013 - 10:06 AM
cheers for the advise guys
#15 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 21 February 2013 - 10:24 AM
I have been polishing ally since my first moped in 88, don't waste money of special cloths, its a load of rubbish. The only thing that can scratch ally is anything HARDER than ally, therefore unless you wear diamond shirts then any old rag will do. I find torn up old t shirts to be best. Don't worry in what direction you polish, but nice gentle movements are best, whether in as straight line or round and round. A drill mounted kit with 'soap' makes a big difference if you are going to do a lot.
