I haven't updated this in a while as dismantling things doesn't make for very good pics. Can I just say, whoever decided it was a good idea to make shear bolts on the steering column mandatory should be made to remove 10 mini pedal boxes!
So, first things first I welded up the door as it had cracked
Only joking, that certainly wasn't me - some people really shouldn't be allowed to operate power tools though!
De-skinned the doors, this lot was floating around in the bottom
Scuttle was rotten around the windscreen seal and under the wing
So, off with the scuttle
Started cutting the rot out and replacing some metal as making holes was getting rather depressing!
The inner wings are also being replaced as the front halves have been replaced extremely badly after an front on accident, the replacements were 1/2'' out!
The other ends aren't much better
This is going to be fun to repair too, rust has got under the cross member seam and rotted the bulkhead out in places
