Hi all,
Just wondering is it easier to install the inside Universal Joints to the motor before installing it in the car or is it easier to fit them once the engine is installed. And / or should you fit them drive shaft side first or engine side???
Peter
Engine Installation
cjhols
, Feb 23 2013 06:13 AM
5 replies to this topic
Posted 23 February 2013 - 06:13 AM
Posted 23 February 2013 - 10:52 AM
What type of joint are you referring to? Hardy Spicers?
Posted 23 February 2013 - 11:16 AM
Yep. Typical universal with plastic or nylon white end caps that cover and and are held by u bolts. Just at the ends
Posted 23 February 2013 - 11:39 AM
That as described is a Hardy Spicer conversion from the original rubber cruciform joints, which was a definite improvement in longevity, although it causes some minor drive train vibration. There is just about enough room to fiddle them in with the engine in place. I suggest that you fit them while the engine is still a few inches above its final resting place, to get more working room, and tighten fully once the engine is in place.
It really does not matter which side you fit first, and you could fit them loosely to either the engine or driveshaft first. It is your hands which will be doing the job, just do what you find easiest. Sometimes there is an important "right" and "wrong" way, but not so in this case.
Posted 23 February 2013 - 12:25 PM
Quniton Hazell QL5000 conversion, Hardy Spicers are standard joints used on other models.
Personally I would have them fitted to the gearbox first and connect the driveshaft side in situ. As above though it doesn't matter which goes in first really.
Posted 24 February 2013 - 01:15 AM
Thank You.
all good
all good
