Hi all, i've just done a bit of rust repair on my scuttle and have sprayed the area with the colour of my car! However there is a colour difference between the two bit of paintwork! Just wondering if you have any tips for making the paint look the same? i dont really want to spray the whole front wing to make it the same! Cheers Chris
Blending new paint ???
01smartc
, Apr 13 2006 04:55 PM
4 replies to this topic
Posted 13 April 2006 - 04:55 PM
Posted 13 April 2006 - 06:21 PM
It depends on how far away it is. Personally, I'd leave it a couple of weeks and then use a decent cutting compound such as 3M or G3/4 by Farecla. Let the paint settle and dry properly first for as long a time as you can first though or you'll risk dragging it all off or burning it.
Posted 14 April 2006 - 09:00 AM
I was just about to ask this same question. I have sprayed around my front wheel arch but its really obvious where the new paint is. will the cutting compound take the edges off and blend it all in nicely?
Posted 14 April 2006 - 11:21 AM
It will take the edges off it and blend it, but it wont make the colour match up..
when blending a panel it is better to have a soft line rather than a hard masked line where you painted to.
This will help the new paint blend with the old.
Assuming you are using a spray can
when you prime the section, de-mask it all, rub the primer smooth and then move outwards a couple inches and re-mask.
but instead of masking a solid line take a length of masking tape and roll it so it becomes a long tube (sticky side out)
stick that to the panel and then attach the other tape and paper to that. effectively creating a soft rolled edge. The idea being some paint gets under the edge and does not leave a hard line.
This is easier to blend.
I will try do a blend and take pics as it is easier to show somepoint in the coming week
If you are using a spray gun, a similar method is used to above but you can move the masking further out
as you have more control over the spray pattern.
With the spray gun, I tend to put some thinners in the gun and give the edges a very light and quick spray pass, as it helps it all blend.
Posted 14 April 2006 - 12:45 PM
thanks shaz, ill give that ago and see how it turns out. Cant be any worse than it already is. saying that though i have some rust on my scuttle and front panel so I think it would be easier to sand this all back, treat the rust and then spray the whole front end then it would all match nicely
