Posted 23 February 2013 - 05:42 PM
ive got a 1981 998cc mini with drum brakes, im looking to upgrade to discs but unsure on what i can get, ive seen these:
http://www.minispare...px|Back to shop
would they be able to replace the drums i have now? my wheels are also 12" not 10" if that matters
cheers
-bud
Posted 23 February 2013 - 05:52 PM
But if you want 10" wheels - you might be best off getting the complete 7.5 " conversion kit which is about £500
Posted 23 February 2013 - 05:54 PM
It may just be easier for you to convert to 7.5" discs and use 10" wheels as you can buy this as a whole kit from Minispares:
Though the callipers are out of stock at the moment, there will be more in early march. Hope this helps. Noah.
Edit - Forgot to mention, a TMF+ Discount will give you a 7.5% discount from Minispares. So its worth investing in the £5 for a subscription. Giving you a discount of around £30 on the brakes. I think. I'd check, my maths isn't that great.
Edited by Noah, 23 February 2013 - 05:56 PM.
Posted 23 February 2013 - 05:56 PM
Posted 23 February 2013 - 06:01 PM
Posted 23 February 2013 - 06:04 PM
Posted 23 February 2013 - 06:06 PM
Explain to him what you think you need and what you are unsure of and he'll be able to help!
Posted 23 February 2013 - 06:07 PM
Posted 23 February 2013 - 06:11 PM
Edited by Dan, 23 February 2013 - 06:11 PM.
Posted 23 February 2013 - 06:17 PM
http://www.ebay.co.u...=item1c2d24c70a
Edited by Buddy, 23 February 2013 - 06:17 PM.
Posted 23 February 2013 - 06:19 PM
Posted 23 February 2013 - 06:22 PM
Posted 23 February 2013 - 07:02 PM
You just need a bog standard set of 1983 onwards 8.4" disc brakes, hubs, pipes and calipers as you would find on fleebay etc. Buy new calipers if you are unsure how to check and and fit new seals to a used set. This will probably start world war three but vented discs on a road going mini are a waste of time and money and yes I have used them.( more unsprung weight, more bump steer, less feel ) Also stick to genuine AP lockheed pads and avoid ebc greenstuff and similar as despite the hype they are vague until they warm up and feel worse than a well set up drum brake around town.
I found my green stuff pads and cross drilled discs worked much better than standard( ESPECIALLY when cold). But they are 7.5 inch though. Superb stopping power, but of course tyre choice is important as well.
Posted 23 February 2013 - 11:20 PM
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Yellow Tag Brake Master Cylinder QuestionsStarted by John K Series , 12 Mar 2026 |
Time To Bleed The BrakesStarted by Murrayup , 11 Mar 2026 |
Clutch And Fan Noise From Newly Rebuilt 1380 Engine.Started by sam138 , 19 Feb 2026 |
1968 Cooper Parts NeededStarted by Neilmr , 14 Feb 2026 |
New Rear Drums Locking/bitingStarted by SteadyEddie , 11 Feb 2026 |
