Bonnet Pins
wrinkles_2
, Feb 24 2013 10:32 PM
9 replies to this topic
Posted 24 February 2013 - 10:32 PM
I am thinking of putting a set of bonnet pins on my mk3 mini, what way will I go by it. (eg, what size of plates)
Posted 24 February 2013 - 10:48 PM
For a removable bonnet?
Posted 24 February 2013 - 10:55 PM
Yes
Posted 24 February 2013 - 11:58 PM
Rear ones go to the corners at a 45° angle like this:
You need to fit a plate of 2mm thick alluminum on the inside or the fixings:
Roughly this is 9 cm at the scuttle side and 12 cm at the wing.
You can get a 14cm x 14cm square plate and cut it half at the diagonal, then pop-rivet it to the scuttle and the inner wing.
Posted 25 February 2013 - 05:43 AM
Iv just fitted to mine I done mine wrong in a way I rushed into it and started drilling I should of placed the top part round the other way but oh we'll just means I have bigger plates
And the plate was just a thick bit of alloy in a shape of a triangle just make you measure lots of times or will look crap if out of place
Posted 25 February 2013 - 09:55 AM
What about the front? what size of plates etc.
Posted 25 February 2013 - 11:23 AM
Never bothered with pins for the front as you can fit rubber catches, spring type or even leather straps
Rubber hooks:
Just a word of warning, check them regularly for cracking and once they're craked replace them, the rubbers will usually need replacement after about 2 years, but you can get them for a couple of quids
Rubber hooks:
Posted 25 February 2013 - 07:58 PM
I am going pins at back and springs at front or straps / strap
Posted 25 February 2013 - 09:34 PM
I am looking to put bonnet pin on the front and back of the bonnet.
Posted 25 February 2013 - 09:35 PM
Sorry pins.
