Manifolds And Carb Icing
14 replies to this topic
#1 crock
crock
  • 90 posts
Posted 26 February 2013 - 07:23 AM
If running a single HIF 44 or dual SU's, do you really need a water heated intake manifold to avoid carburetor icing? I figure if anybody should know it should be you guys in the UK.
Thanks!
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 26 February 2013 - 07:33 AM
I'm not sure heating the manifold will stop carb icing, there will be very little if any heat transfer between manifold and carb!
#3 Barman
Barman
  • 1,068 posts
Posted 26 February 2013 - 07:44 AM
There is a looooong discussion about the subject here...
#4 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 26 February 2013 - 07:56 AM
I'd imagine you'll be okay in California, but an alternative may be to replumb the carb so it's on the heater feed, that way your inlet manifold is heated while your internal heater is on (when it's cold), and off when it's off, (presumably 364 days of the year in Cali).
Dave
#5 jaydee
jaydee
  • 8,565 posts
Posted 26 February 2013 - 09:35 AM
In california you can have carb icing due to the excessive dump
A heated manifold has nothing to do with carb icing
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 February 2013 - 09:38 AM
You can't say California is an excessive dump! OK LA maybe and Hollywood certainly but there are some lovely parts of the state.
#7 MRA
MRA
  • 7,607 posts
Posted 26 February 2013 - 09:39 AM
A what ?
#8 jaydee
jaydee
  • 8,565 posts
Posted 26 February 2013 - 09:42 AM
Heated intake manifold Martin
#9 MRA
MRA
  • 7,607 posts
Posted 26 February 2013 - 09:50 AM
No the bit about an excessive dump ?
Interstingly I couldn't find anything to do with the nice little thermal barrier that is situated between the carb and manifold, the 3 gaskets and the phenolic (plastic in laymans terms) spacer which is there to reduce heat transfer, I have only ever witnessed carb icing on an SU carb when there has been a fue leak, once on the 3 counties rally at about 03:00am (coffee sorted it out once, then another ...... well lets not go into that) and a few times on the road, its more common with cross flow engines as the exhaust (hot air source) is the other side, Mini has the exhaust sitting underneath and supplies enough warm/hot air to stop it from occuring at least in most cases anyway.
#10 jaydee
jaydee
  • 8,565 posts
Posted 26 February 2013 - 09:58 AM
There was a thread about that on the MG forum once, sounds like they've got very high humidity over summer in california, that rings a bell about the carb icing problem
I have to say in most cases other fuelling problems are mis-diagnosed as carb icing
#11 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 26 February 2013 - 10:02 AM
Attached File  DSC00144.JPG   26.21K   10 downloads
Attached File  DSC00146.JPG   53.76K   15 downloads
Poor photos, but the whole carb was frozen - the piston was frozen in the dashpot !
Soon defrosted once stationary, but that was the result of a 20min drive in cold damp weather - I don't think it was even freezing.
A heated intake manifold doesn't prevent it, but it seem to do a smidgeon to prevent it - I've had icing on most all of the cars I've driven that have an alloy intake. Sometimes the throttle sticks open, sometimes it just stumbles to a stop when the piston jams.
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 February 2013 - 10:09 AM
Dashpot and throttle heaters were fitted by BL in arctic regions. Never seen one though. The weather doesn't have to be freezing because a carb is essentially a refrigerator.
#13 Spitz
Spitz
  • 1,716 posts
Posted 26 February 2013 - 03:12 PM
Carb heaters were fitted to MINIs in the 70's bound for CA ( and Switzerland I think )
These had a heated coil in a spacer between the manifold and carb, and also a heated band that went around the dashpot ( HS2 and HS4 ).
You could fit one of these if need be.
#14 crock
crock
  • 90 posts
Posted 26 February 2013 - 03:25 PM
Thanks for the info.
#15 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 26 February 2013 - 06:04 PM
I ordered one of these very bands from SU a few months ago for my suck through charger setup, the carb would suffer icing when there is excess humidity in the air, summer or winter. I also fitted a tiny little heating element in the air filter at the mouth of the carb, I am sure how effective this was alone, but certainly the combination of that, and the heated strap worked very well.
