So I hope you lot have learnt from my stupidity and yes its safe to take the car out in the ice otherwise I would not be entering these details sorry about the paint Ed
Black F****** Ice Anyway I'm A Terrible Driver
joss
, Feb 26 2013 06:16 PM
10 replies to this topic
Posted 26 February 2013 - 06:16 PM
I know I should have not taken the car out but its meant to be driven not ogled at. So floored it hit some black ice it threw the back around then I hit a dry patch and the car launch control all by itself in to a tree (great fun). Surprisingly not much damage 2 new arches, outer split rims, bumper,wing, a panel and a bit of paint and it will be ready for the drier weather HAHA.
Posted 26 February 2013 - 06:33 PM
wow hope you okay? best check the front subframe and hubs etc. by the damage to the wheel i would expect a lot to be bend or cracked
Posted 26 February 2013 - 06:47 PM
gutted! am i correct on thinking you haven't had this on the road long after the conversion?
Posted 26 February 2013 - 06:55 PM
Not good man! Hope the damage is not too bad. If none of the subframes have been bent and you have got away with just the arches and an outer wheels edge then you have done well. Was hoping to see this car at a Basingstoke Mini Club meet. I know we had a bit of a problem with our pub closing down and a meet being canceled last minute but I hope its not put you off. Good luck fixing it and hope to see you and the car soon!
Posted 26 February 2013 - 07:10 PM
The wheel is made of quite thin ally and took a heavy impact and it colapsed if it was a steel wheel i am sure their would have been some damage to the frame but suprisingly on inspection not much damage I have changed the steering rack and bearing hub but fingers crossed everything else mechanically looks fine.
Posted 26 February 2013 - 08:27 PM
aw ffs joss, hope you are ok mate "clean underpants i would think" if you are ordering wheel arches, you would be better to order the wider rear arches? not sure if they would be too big?
As long as you are ok, the car will fix.
The back of that mini steps out without too much trouble in the dry. i think i only had it out in the rain the once when i had my first experience of the arse stepping oot.
Ed
Ed
Posted 27 February 2013 - 08:32 AM
Hi Ed
Yes it is a bit twitchy up the rear end in as far as the arches are concerned the larger type are to big they look like I am still wearing flared trousers. Because of their is minimal vertical movement this set up works fine I went to a rubber seal supplier and they sold me a 20mm thick strip to bring the arch out.
Joss
Joss
Posted 27 February 2013 - 11:31 AM
Joss man, wow.........glad you're OK.
I agree that the cars should be driven at every given chance but after my few experiences in wet and mildly moist conditions I now prefer driving it in the dry.
We look forward to seeing it back on the road yet again.....good luck with the rebuild.
Posted 27 February 2013 - 04:57 PM
I'll let you know a little secret I know more about this Mini or shall I call it an appendage than I do my pet gold fish. Everything should be up an running for April I hope we get to meet in the future mind you we might not have much to talk about
Posted 06 March 2013 - 11:37 AM
It happens to us all at some point, You have the right mind set, to rebuild her again, and get out their. This time when she is ready the warmer weather will be here.Good luck with your rebuild, and love the wheels are they from forge?
Posted 06 March 2013 - 04:36 PM
Thanks for the positive response and the wheels are from force racing
