Acr4 Operation Question
4 replies to this topic
#1 jemo
jemo
  • 38 posts
Posted 26 February 2013 - 10:05 PM
Hi,
Recently bought a 2nd hand ACR4 plus Rover3 pod to use on my MPi. The manuals are pretty useless and I am having some difficulty maintaining communication. Here is what I am doing:
Ignition off and alarm cancelled
Plug in the ACR
- It goes through self check ok then I follow this sequence:- select petrol - select MEMS2J - select Mini
- It seems to read back ECU type and says press OK to start diagnostics which I do.
- Then get menu to read fault codes etc - select read fault codes and it comes back and says no codes returned
At this point I am assuming comms with the ECU have been established and what little info there is in the manual would suggest this to be the case.
At this point I start the car and the ACR4 immediately reports that comms have been lost and to press OK to try to re-establish, which I try but to no avail.
So my Q is am I doing something wrong sequence wise and how do you keep the unit talking to the ECU when you start the engine?
Thanks for any advice
Jeff
#2 Guest_minidizzy_*
Guest_minidizzy_*
  • Guests
Posted 27 February 2013 - 01:10 AM
It may be to do with the harness you are using. The MPi harness (30214000) is for all Rovers MPis except for the Mini which is a special case and communication is likely to fail. It will work with a little modification (joining two pins together but I would need to search a bit to find out which two). A more reliable harness is the 30212400 J1962 which has universal OBD application.
I do not think there is anything wrong with your sequence. if there are no faults then you should set the menu to components to see what all the readings are.
#3 jemo
jemo
  • 38 posts
Posted 27 February 2013 - 09:15 PM
Hi,
Thanks for your reply. The harness I have is the 30214000 as this is the one that is shown as the right cable for the mini in the Sykes-P reference guide. It clearly shows this as being the harness for the mini mpi and I bought it separately from the pod so I hope it is usable. Anything else I can try - has anyone used this harness successfully?
#4 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 27 February 2013 - 10:10 PM
I believe that there is a fix for the cable here:
http://www.theminifo...r-and-mpi-mini/
#5 Guest_minidizzy_*
Guest_minidizzy_*
  • Guests
Posted 28 February 2013 - 01:21 AM
And a little bit more information here:
http://www.spsupport.com/index.php/kunena-forum/7-acr/2190-rover-mini-mpi-1998-a-acr4-problems
SP Diagnostics was a company set up from the buy-out of Sykes Pickavant's diagnostics business.
I have both 30214000 and 30212400 harnesses and I know the second is more reliable. The other harness referred to (30214600) is, I believe, an updated and more expensive version of 30212400.
