Hif44 To Manifold
Posted 26 February 2013 - 11:48 PM
Posted 27 February 2013 - 12:01 AM
Posted 27 February 2013 - 12:03 AM
Older carbs like the HS have a flange that only takes two studs so I wouldn't think it would be too problematic to use only two, but If the stud holes are there in the manifold I would use them, it creates a tighter seal, which as you know if your replacing the gasket is important.
Posted 27 February 2013 - 12:07 AM
Posted 27 February 2013 - 09:30 AM
Posted 27 February 2013 - 11:06 AM
Regards,
Posted 27 February 2013 - 07:27 PM
Posted 27 February 2013 - 07:38 PM
It should work for you....You should be able to simply replace the gasket and use as it has been used. I would however use some sealant on both sides of the gasket to fill any imperfection where it failed previously.
Ideally yes, you should hold a HIF carb with the proper manifold and 4 studs
Posted 27 February 2013 - 07:59 PM
Posted 27 February 2013 - 08:12 PM
If it has a square mating surface and there is room for the additional studs, but no holes are there, then the manifold needs to be removed if you want to drill and thread the holes.
If the threaded holes are there already....you simply screw in two new studs
HS4 manifold
http://www.somerford...oducts_id=13824
HIF manifold ( 38 pictured...but shows the position for four studs
http://www.somerford...oducts_id=13222
I just reread your first post....you mentioned a stud in upper right when facing engine....if that's the case, then you must have a four stud manifold....
Edited by Spitz, 27 February 2013 - 08:18 PM.
Posted 27 February 2013 - 09:08 PM
Thanks for helping me clarify all this. I just notices where you are from so I figure you will understand how hard parts are to get and why I am prepared to drill, tap and repair the existing manifold rather than just changing it out.
Posted 27 February 2013 - 09:18 PM
Sorry to bomb the thread, but this is my set-up, i am using all four studs but the spacer is of a HS4.If you fit it with two studs you'll have an air leak at the two missing
All four studs mind you are VERY tight and using HIF gaskets. I'm not experiencing an air leak as i have had one before and i know what they feel like, it drive beautifully.
Although i am having a different problem, help me please! http://www.theminifo...esponse-needed/
Many Thanks,
Sorry again.
Iain.
Posted 27 February 2013 - 09:27 PM
http://www.hunterclassicsportscars.ca/
Posted 27 February 2013 - 09:48 PM
Posted 28 February 2013 - 12:31 AM
Many Thanks,
Sorry again.
Iain.
In the picture above you mention the studs are VERY TIGHT, with the arrangement above you have a risk of distortion on the HIFs mounting flange, its needs the 4 bolt black insulation block really, dont go cranking up the nuts where there is just fresh air behind the carb flange.
