1.5 Carb With 1.25 Stub Stack
Posted 27 February 2013 - 03:29 PM
Thanks Jack
Posted 27 February 2013 - 03:35 PM
What would the affect of having a slightly smaller stub stack on the carb?
Thanks Jack
It would surely defeat the object of having it....
Posted 27 February 2013 - 04:33 PM
Posted 27 February 2013 - 05:49 PM
1 - A tuned length intake can allow for alteration in torque characteristics
2 - the smooth rounded lip of the stack allows a smoother air intake maintining a better velocity into the head.
A shorter one, will alter 1 but not necissarily 2 unless it is less well made. If it's better made the alteration in 1 may be well worth the improvement in 2.
Posted 27 February 2013 - 08:47 PM
Posted 27 February 2013 - 09:30 PM
Yeah don't use a smaller diameter! That be crazy!
Posted 27 February 2013 - 09:45 PM
Posted 27 February 2013 - 10:17 PM
Posted 27 February 2013 - 10:29 PM
Thought so just checking as some one is selling med style ones on eBay rather cheap ah well
If you're referring to the turner carb ones don't bother unless you're prepared to cut it to fit inside your air filter. They're simply too big for mini filters.
Posted 27 February 2013 - 10:43 PM
Posted 27 February 2013 - 11:12 PM
I had mine cut down to fit inside. The cost of doing that would have made the med cheaper.
If you're handy with the grinder try the turner but otherwise spend the extra on the med. If you can get it to fit, it works great with the ramair. I got a an extra few BHP on the rollers over a cone/somerford stub combo.
Posted 28 February 2013 - 12:40 AM
Edited by Mrpeanut, 28 February 2013 - 12:43 AM.
Posted 01 March 2013 - 02:47 AM
Grinding aluminium with a normal grinding wheel or disc is potentially very dangerous, as the aluminium clocks the wheel, then expands due to temperature and cracks the wheel, often resulting in an explosion of grindigng wheel etc..
Posted 01 March 2013 - 10:06 AM
A medium grit flap wheel will cut through it pretty smoothly though, take pauses to let the temp drop.
