Panel Replacement
1 reply to this topic
#1 spraymaster
spraymaster
  • 51 posts
Posted 28 February 2013 - 09:19 PM
coulkd i have some advice on the panel where the door hinge is please basically the driver door opens and the check strap was pulling on the the panel and pulling it were the window screen meets the panel ect so someone welded a plate around the check strap bobs your uncle alot stronger but i wanted to know if you can get a replacement panel i want it done properly or do you think it will be ok as it is
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,040 posts
  • Name: Neil
Posted 28 February 2013 - 09:22 PM
Yes you can there is the A post but i would remove the plate to see whats going on. If its just a crack or minor rust then chop out the damage and weld in some fresh steel.
