Hot Choke Cable
Posted 02 March 2013 - 04:41 PM
Tried to start the mini after it's hibernation but have problems.
At first the engine turned over but not fire up. I thought I had flattened the battery as it became sluggish and finally just a click/clunk noise. I then noticed the choke was very hot to touch. Am i right in thinking i now have a shorting out somewhere? Could it be the starter causing the problem or the battery ( I dont think it is the batterey however it's now off the car and charging up. Is there an easy way to test the starter off the car? Its a A+ engine with a pre-engaged starter with the solenoid on the starter (if that makes sense)
Cheers everyone
Posted 02 March 2013 - 04:43 PM
Posted 02 March 2013 - 04:46 PM
Posted 02 March 2013 - 04:54 PM
Posted 02 March 2013 - 05:02 PM
Posted 02 March 2013 - 05:08 PM
Posted 04 March 2013 - 11:42 PM
Posted 04 March 2013 - 11:47 PM
Posted 04 March 2013 - 11:56 PM
Posted 05 March 2013 - 08:15 AM
Posted 05 March 2013 - 12:08 PM
Posted 05 March 2013 - 01:21 PM
Posted 05 March 2013 - 01:34 PM
Posted 05 March 2013 - 01:47 PM
Posted 05 March 2013 - 02:29 PM
Starter cleaned and back on the car and cleaned engine earth strap - still not working - used jumpleads as additional earthing straps and hey presto turn of the key and he bursts into life - yes it's an earthing problem and a new strap is on the shopping list - I should listen to you guys and go straight to earthing - would have saved me a lot of time! Thank you to all who have helped me get me to the route of Golly-Gosh's problem
Glad your sorted mate.
