How To Tell If You Got A Good Block
3 replies to this topic
#1 sam138
sam138
  • 521 posts
Posted 02 March 2013 - 06:32 PM
getting started on a rebuild of a 1275 mg metro stripped the block of and given it a degrease , how do i tell if it needs a rebore or a hone and if it is a good block to use . the bore look good and only have minor surface rust they feel smooth and seem to have the cross marking still is this good . And the only thing i can see on the outside of the block there is a tiny hole that goes through shown in picture but does not go into block look to go from side of surface block to the underside bit will this be ok .
http://www.flickr.co...in/photostream/
http://www.flickr.co.../in/photostream
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 02 March 2013 - 07:44 PM
one of the bores is showing signs of where the piston/rings picked up and in my mind its going to need more than a hone, have you measured the bore to see if its been bored before? std bore on the 1275 is 70.61mm
#3 sam138
sam138
  • 521 posts
Posted 03 March 2013 - 04:21 PM
yes have measured the bores and it is a standard bore block so would going to the next size up 1293 be ok is there any gain going 1310 or 1330 power wise .
#4 Ethel
  • 26,580 posts
Posted 03 March 2013 - 05:17 PM
2nd last piccy looks bad.
