Hi Guys i am have a big issue with get the upper arm out so i can replace my saggy cones, i can not seem to get the upper arm off the wheel hub no matter how much force i put on it will not move. You guys got any ideas how i can get this off? Thanks!
Upper Arm Removal Issues
jakepalmerd13
, Mar 02 2013 06:34 PM
3 replies to this topic
Posted 02 March 2013 - 06:34 PM
Posted 02 March 2013 - 06:49 PM
I aasume you mean the top ball joint to the top arm, its a taper so you have to either use a ball joint breaker or a shap hit with a hammer on the upper arm inline with the taper, they can be very tight and wont simply lever apart no mater how much force you put on it.
Posted 03 March 2013 - 01:05 PM
Yh i try give it a good whack but it ant move will have to buy a ball joint brake thanks
Posted 03 March 2013 - 04:08 PM
I remember them.
I use a fork and a 4lb hammer called THOR. I get a good swing and smack the fork, out the joint pops. I've never gotten one of those screw ones to work. So I just hit it harder. Like the animal I am.
