Rear Fog Light Switch
13 replies to this topic
#1 M30
M30
  • 42 posts
Posted 02 March 2013 - 07:15 PM
Evening chaps,
I've done most of the wiring today (converting a 1990 Cooper to centre speedo with a full new loom) just have the rear fog to sort and washers.
The car only has 4 switches on the centre panel, 1 lights, 2 hazards, 3 heated rear window, 4 brake test. Where would the rear fog switch normally go? should the car have a 5 switch panel? I was thinking of doing away with the brake test switch, but was just curious??
Stu
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 02 March 2013 - 07:30 PM
Seem to remember on certain models they were in a seperate switch panel under the dash to the right of the steering column
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 March 2013 - 08:05 PM
on a 1990 coope,r on a separate switch panel under the dash on the right hand side (next to the wheel arch)
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 02 March 2013 - 08:08 PM
you can just see it here
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 03 March 2013 - 12:16 AM
The brake test switch is actually a legally required (although not MOTd) warning lamp.
5 switch panels are only compatible with the ratchet choke cable.
#6 Ethel
  • 26,580 posts
Posted 03 March 2013 - 01:30 AM
You could replace the brake test switch with one on the handbrake & a warning light.
#7 adam_93rio
adam_93rio
  • 3,271 posts
Posted 03 March 2013 - 02:18 AM
Without sounding like a *******, you can use any choke cable with the 5 switch panel. The 5 switch panel was standard in my 93 carb'd mini and I prefer the locking style choke do it was swapped
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 03 March 2013 - 10:24 AM
You can do but it doesn't exactly fit well and slops about it the larger D shaped hole, you have to fasten it up way tighter than it's meant to be. Does it even fit centrally in the hole without filing a flat onto it?
Edited by Dan, 03 March 2013 - 10:40 AM.
#9 midridge2
midridge2
  • 1,794 posts
Posted 03 March 2013 - 10:51 AM
i am baffled, the brake test switch is a indication of fluid level in the master cylinder, by replacing it with a handbrake switch that only tells you the handbrake is on/off
#10 adam_93rio
adam_93rio
  • 3,271 posts
Posted 03 March 2013 - 11:45 AM
I used a black washer, didn't require too much tightening, and it's been there 4 years now without a problem
#11 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 03 March 2013 - 12:00 PM
i use a clothes peg on my choke cable,
#12 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 03 March 2013 - 12:48 PM
the hand brake switch is there to tell you the light works, so that when the level in the chamber falls below a certain level it will be on constantly
#13 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 03 March 2013 - 02:05 PM
i'm lost, the op asked where the fog light switch goes and most of the answers above are talking about the choke cable and brake fail test switch light
#14 midridge2
midridge2
  • 1,794 posts
Posted 03 March 2013 - 02:13 PM
yep bungle, thats the way tmf works,ask one question and get told the answer to 5 other things.
