Window Winder Issue
1 reply to this topic
#1 1275MIN
1275MIN
  • 130 posts
Posted 03 March 2013 - 12:59 PM
Hi All,
As i wind down my window my window decides to open at an angle.
Ive popped the door card off and i can see that runner has become seperated from the glass.
Are these runners crimped on opr stuck on? What can i do to resolve this issue?
#2 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 03 March 2013 - 01:14 PM
They are basically just push fitted in place, what tends to happen is that rain water gets in and corrodes them causing them to swell and detach/seperate from the glass at one end. If the corrosion isn't too extensive you can sometime remove the runner, grind the rust away, then repaint, reshape and refit, but if it's too bad then you will need replacement runners.
If you do replace then make sure that you order the correct part though as they are "sided/handed"
Edited by AVV IT, 03 March 2013 - 01:15 PM.
