Mini Gear Issues
4 replies to this topic
#1 green sprite
green sprite
  • 68 posts
Posted 03 March 2013 - 05:49 PM
Hi,
Im having issues getting my mini in gear. I think this is likely the clutch as its all the way to the floor when changing gear.
Any one know how much a new clucth will cost me to have fitted?
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 03 March 2013 - 06:12 PM
Is it the clutch or the clutch hydraulics ? Is there lot of free play before you feel and pressure on the pedal, if the clutch hydraulics has air in due to a cylinder problem or a leak of clutch fluid you would have a pedal that drove just off the floor and trouble getting gears. Have you checked the level and looked for any leaks
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
in a specialist garage about £200, in a every day garage probably more and a heap load of trouble...
#4 green sprite
green sprite
  • 68 posts
Posted 03 March 2013 - 06:20 PM
aww pricey. ill check the fluid levels first.
Thanks.
#5 MRA
MRA
  • 7,607 posts
Posted 03 March 2013 - 08:09 PM
Also check the linkage and pivot points for wearor damage.
