hi i want to remove some black dash rails from another mini and reuse them in mine but how do you remove them? do i need to fit the front windscreen before refitting the top one or can it be done before? thanks tom
Removal And Refitting Dash Rails How?
ToM 2012
, Mar 03 2013 06:41 PM
6 replies to this topic
Posted 03 March 2013 - 06:41 PM
Posted 03 March 2013 - 06:46 PM
I managed to get mine out without damage the top one that is, 3 bolts, one at each and and one in the centre. then its a lot of yanking. I pulled one end up and then sort of kicked the other end up and it just sorta popped out
Bottom one I think needs the switches and choke cable disconnected and the chrome locking strip removed and then pulls off.
Posted 03 March 2013 - 06:53 PM
ok cheers did you have to remove the clocks and etc out the way?
Posted 03 March 2013 - 06:56 PM
To get the top one, nope.
I've not removed the bottom one as only a small bit of the top dash rail is being painted.
Posted 03 March 2013 - 07:02 PM
oo ok would you fit the top one after the windscreen is fitted or could you fit it now and then fit the windscreen after? cheers tom
Posted 03 March 2013 - 07:05 PM
Fit the top one then fit the windscreen, you can get them out with the windscreen in, not so easy getting it back in.
Posted 03 March 2013 - 07:13 PM
ok mate cheers ile fit the top dash rail first then the windscreen cheers
