All of a sudden, my engine has starting pinking ever so badly. It is a metal on metal sound. It was fine one minute, put it in the garage, then the next day when I went to drive it, it was pinking under load in all gears?
It has been getting progressively harder to start in the morning, however I have put this down to the cold weather...
The car will idle perfectly fine, and will rev freely under no load with no pinking. I took the vac advance pipe off the carb and created a vacuum and the dizzy plate rotates fine. I have the aldon electronic ignition which rids of the points and condensor).
The clamp is tight on the distributor so it is not as if it has rotated.
I don't have a timing light to hand at the moment so have been unable to check this.
I have richened up the mixture slightly (by one flat of the nut), but this has made no difference.
The only thing could be dodgy fuel, however what I don't understand is how it was fine when I was driving it, then the following morning, it was pinking like a
It is a 998 engine.
Any thoughts or ideas is appreciated.
Thank you in advance (excuse the pun
James
