Torque Converter Bolts
14 replies to this topic
#1 smartie93
smartie93
  • 285 posts
Posted 06 March 2013 - 04:12 PM
As above does anyone know what type of bolt they are. I've lost all my original ones so I can't find out :(
I'm on about the ones that hold it to the flywheel by the way
Edited by smartie93, 06 March 2013 - 04:13 PM.
#2 Barman
Barman
  • 1,068 posts
Posted 06 March 2013 - 04:45 PM
Does this help...?
#3 smartie93
smartie93
  • 285 posts
Posted 06 March 2013 - 04:57 PM
I've already had a look at it, they're part 25, not a lot of info unfortunately :/
I need to know the thread type, size etc so i can buy longer ones for my flywheel puller
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 06 March 2013 - 05:20 PM
They are 5/16 UNF.
Depending upon the puller you'll need to get some about 3 to 4 inches long, and use a big flat thick washer under the head on the puller...
I actually use cap head screws
#5 smartie93
smartie93
  • 285 posts
Posted 06 March 2013 - 06:49 PM
Thanks a lot :)
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 06 March 2013 - 10:28 PM
Umm, if you've lost them and need to use a puller does this mean you have removed all the bolts from the torque converter while it's fitted to the car?
#7 smartie93
smartie93
  • 285 posts
Posted 06 March 2013 - 11:13 PM
Umm no, what gave you that idea? haha
I removed the bolts just before we moved house, so they're probably in a box somewhere. The engine's been sitting in my garage for 10 months, so i decided It's better in bits than to just end up as one seized lump. the crank is useful to me as well :)
<< That engine in my photo is the auto
Edited by smartie93, 06 March 2013 - 11:20 PM.
#8 MRA
MRA
  • 7,607 posts
Posted 07 March 2013 - 12:28 AM
if you removed all 6 bolts then you have a 99.99% certainty of destroying your convertor, there are stator plates, shims and seals that these bolts hold in place and they always move.
Edited by mra-minis.co.uk, 07 March 2013 - 12:30 AM.
missed off the impoertant part :-(
#9 smartie93
smartie93
  • 285 posts
Posted 07 March 2013 - 01:42 PM
So whenever you remove a torque conveter you destroy it?
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 March 2013 - 01:44 PM
to remove a torque converter, you only need remove 3 of the 6 bolts holding the converter together.
#11 smartie93
smartie93
  • 285 posts
Posted 07 March 2013 - 01:49 PM
Ahh okay, oh well, it wasn't going to run again anyway.
Which three should I have undone?
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 March 2013 - 01:52 PM
any three, which are not adjacent to each other..
#13 smartie93
smartie93
  • 285 posts
Posted 07 March 2013 - 01:55 PM
so the bolts just hold the converter together, you take three out for the puller, and the converter is held on by a taper?
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 March 2013 - 01:57 PM
yup, same as the flywheel on a manual, as they both fit on the same crank.
Edited by Guess-Works.com, 07 March 2013 - 01:58 PM.
#15 smartie93
smartie93
  • 285 posts
Posted 07 March 2013 - 01:58 PM
Thanks for the explaination :)
