Rebore Costs?
Posted 08 March 2013 - 11:53 AM
Posted 08 March 2013 - 11:56 AM
Pistons up to about £450 for Omegas or Powermax around half that
Posted 08 March 2013 - 12:00 PM
Posted 08 March 2013 - 04:28 PM
I went for p21253's from Minispares after being recommended them from TMF
Posted 08 March 2013 - 04:29 PM
Posted 08 March 2013 - 04:31 PM
well engine has been rebuilt and is awaiting placement into the fresh painted shell. All I can say is that Cooperman and many other TMFers recommended them (I spent hours reading threads about piston types/recommendations on TMF)Oops, how much were they and are they anygood??
Oh and got TMF+ discount
Edited by cliche, 08 March 2013 - 04:31 PM.
Posted 08 March 2013 - 05:01 PM
Allow between £20 & b£25 per bore with £20 being more likely if it's just 0.020" larger.
Then you'll need a crank re-grind at c.£50, main and big-end shells, crank thrust bearings, oil pump, cam followers and timing chain.
Then a full gasket set plus any work needed on the head such as new valve guides, valves (usually just exhausts, valve seat re-cutting and a head surface skim (c.£25)
After doing that you'll have a super engine.
Posted 08 March 2013 - 10:02 PM
Posted 08 March 2013 - 11:54 PM
Ac
Posted 08 March 2013 - 11:58 PM
Posted 09 March 2013 - 11:13 AM
While that looks like a lot more than you *can* get it done for, the equipment they use is better than the mobile boring bar that get strapped to the top, and the honing process is also very good.
Posted 09 March 2013 - 11:42 AM
Posted 09 March 2013 - 01:19 PM
Posted 09 March 2013 - 01:33 PM
Also some boring machines will NOT cut offset bores, if you need an offset make sure they can do it for you
Posted 09 March 2013 - 10:45 PM
Just out of curiosity, how much do you charge for a cank regrind? As I know of a friend with a 1275 now in bits that had only done 25k, but unfortunately run low on oil destroying the bearings.I charge £135 including a surface, a clean is £25 (hot wash tank only)
