Front Panel Differences
10 replies to this topic
#1 Mr.tross
Mr.tross
  • 72 posts
Posted 08 March 2013 - 07:32 PM
How do I tell the difference in front panels between the early and late ones?
#2 rally515
rally515
  • 3,848 posts
Posted 08 March 2013 - 07:34 PM
I know the mpi minis & coopers had a cut out for the oil cooler.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,034 posts
  • Name: Neil
Posted 08 March 2013 - 07:35 PM
Upto 76 they were solidly mounted at the front.
#4 scott_65_cooper_s
scott_65_cooper_s
  • 104 posts
  • Local Club: open to suggestions
Posted 08 March 2013 - 07:58 PM
Really early ones (pre 64 ish) didn't have the cutouts at the bottom corners. Instead a long sweeping curve all the way round the bottom.
#5 blackbelt1990
blackbelt1990
  • 2,614 posts
  • Local Club: Minimus Maximus
Posted 08 March 2013 - 08:18 PM
That's on valances. ;)
#6 scott_65_cooper_s
scott_65_cooper_s
  • 104 posts
Posted 08 March 2013 - 08:52 PM
Or front panels, depending on your terminology :-)
http://www.somerford...&products_id=90
#7 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 08 March 2013 - 10:11 PM
The very early minis, up to 1963, didnt have the notches cut out on the corners. It was only later on, that they were added to aid brake cooling.
But how much it helps for a road car is questionable!
Edited by mk=john, 08 March 2013 - 10:13 PM.
#8 tiger99
tiger99
  • 8,584 posts
Posted 09 March 2013 - 12:14 PM
I think that on the early drum brakes, every little bit helped!
#9 blackbelt1990
blackbelt1990
  • 2,614 posts
Posted 09 March 2013 - 01:26 PM
Yepp, just didnt know how much the OP knew =]
#10 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 10 March 2013 - 02:55 PM
Around 1966 they added not only the corner cutouts but they changed the slam panel brace to "diagonal" to allow use of the horizontal oil cooler. Prior to that the front panels had a vertical brace near the center. When an oil cooler was fitted it was vertical and mounted below the dynamo.
#11 Mr.tross
Mr.tross
  • 72 posts
Posted 12 March 2013 - 10:15 PM
Cheers for the replies
