Hi I have a lot of water from the radiator overflow hose dripping . Have replaced the cap but would The lack of a thermostat cause it to do this.i am in Australia and it is 97 F today :)
Radiator Thermostat
cjhols
, Mar 10 2013 05:49 AM
4 replies to this topic
Posted 10 March 2013 - 05:49 AM
Posted 10 March 2013 - 11:03 AM
Lack of a thermostat won't cause overflow. not recommended to run without thermostats though, especially in winter. if it only a small amount , the internals adjust and then stay in balance (ie water drip stops)
Easiesy thing is to get an overflow tank, when hot overflows into tank, when cooling it gets sucked back into radiator. don't overfill the overflow tank , allow room for the expansion
Posted 10 March 2013 - 11:29 AM
Its not recomended to run without a thermostat at ANY time of the year..... no 4 cylinder will NOT be cooled correctly, I suspect that your gauge is either reading a little below normal or very close to normal..... no 1 cylinder is being cooled ok, no is running hotter then no3 is hotter still and on to no4 which is probably in the red.
You need to fix the issue, the thing to look for is the way the fan has been fitted it can be fitted the wrong way around, look at the shape of the aerofoil ! he direction below.
Engine ( radiator
( = the end shape of the fan blades.
Engine ( radiator
Edited by mra-minis.co.uk, 10 March 2013 - 11:30 AM.
Posted 10 March 2013 - 11:30 AM
You need to check that your rads in good condition and the core is not choked with dust and much, also the fan belt is adjusted correctly with those sort of outside temperatures every thing on the cooling system needs to be in good condition, there is a sleeve available you can fit if you need to run without a thermostat (Not Recommended) to ensure good water circulation from the mini suppliers.
Edited by KernowCooper, 10 March 2013 - 11:31 AM.
Posted 11 March 2013 - 05:17 AM
Hi I discovered that I had put the wrong type of radiator cap. The seal/spring assembly wasn't long enough. All good now.
