Battery/ Starter Motor Issue
4 replies to this topic
#1 tomb1992
tomb1992
  • 490 posts
Posted 10 March 2013 - 03:17 PM
hello!
Having a very annoying issue where my battery it will last as little as a week or if i'm lucky a month before the car wont start and it needs charging :angry: . just got a new battery and been playing around with my vault meter and find that when i try and start my mini the battery drops from 12 volts to 10 before the car finally fires up.
So my question is would this be what is effecting my battery life and the reason for my unpredictable recharges?and would this drop in volts be coursed by a on the blink starter motor :huh: ?
helpful comments would be much appreciated. Tom
#2 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 10 March 2013 - 03:23 PM
Voltage drop when starting is normal. Things to check are that the battery receives around 13.5v with the engine running and that there is nothing draining it like an alarm. To me is sounds like your old battery was knackered, see how you go with a new one but don't expect it to be able to start the car after more than a few months standing, they self discharge
#3 Dark Angel
Dark Angel
  • 59 posts
Posted 10 March 2013 - 03:31 PM
Like Luke said. Check the voltage with the car off. Should be around 12V. Start the car. It should be around 13.5V running with nothing on (lights, etc.) if it isn't than I would suspect a bad alternator.
#4 tomb1992
tomb1992
  • 490 posts
Posted 10 March 2013 - 03:47 PM
arh okay then just thought id ask about the volt drop. with the new battery its reading 12 v standing and around 13.5V running so prob will be a case off running it and seeing what happen' s. thanks guys :thumbsup:
Just out of curiosity why is it that if i run the car with the choke out the more volts i read on the volt meter. with the car running with the choke out a bit it was reading 14.23 volts and .13.5 with out?
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 March 2013 - 05:25 PM
does the fast idle cam on the choke increase the engine revs ? if so theres your answer
