Vtec Or R1
15 replies to this topic
#1 Minimad1995
Minimad1995
  • 14 posts
Posted 12 March 2013 - 12:06 AM
Can someone tell me what is the difference between them? Such as speed and how much they both cost to day?
#2 rally515
rally515
  • 3,848 posts
Posted 12 March 2013 - 12:25 AM
R1 = expensive yet fun on a carpark.
V-tec= daily usable & cheaper
#3 jaydee
jaydee
  • 8,565 posts
Posted 12 March 2013 - 10:22 AM
A v tec conversion is proved to screw weight distribution and give a crap handling, much better the R1. This time you can have problems with chains, but the only place where a vtec needs to be is in a honda.
There are other popular conversions like micra, vauxhall etc all better than a vtec...
#4 minimaxie
minimaxie
  • 1,687 posts
Posted 12 March 2013 - 10:48 AM
http://www.theminifo...-cars-projects/
http://www.16vminiclub.com/
Get reading ;D
#5 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 12 March 2013 - 11:25 AM
One has a sensible reverse, the other doesn't.
Both change the handling and driving characteristics dramatically - it's up the the end user to decide whether for better or worse.
I like A-Series better.
#6 Samwise777
Samwise777
  • 221 posts
Posted 12 March 2013 - 05:02 PM
Vtec all the way, the sounds of a vtec will put a smile on your face everytime
#7 rids
rids
  • 670 posts
Posted 12 March 2013 - 05:39 PM
biased answer but micra conversions still drive and handle like a mini
#8 tom130691
tom130691
  • 147 posts
Posted 12 March 2013 - 07:56 PM
r1 engine and clutch isnt designed to pull the weight of a mini 2-3times the mass its designed to move, if you want to pull away at 5k and go through clutchs go for it
if you like understeer and wheel sping go vtec
if you want a fun nippy car just tune and play with a 1275lump
#9 rally515
rally515
  • 3,848 posts
Posted 12 March 2013 - 08:02 PM
4wd rear engined v-tec mini wouldnt suffer for the above if done correctly but depends on op's budget
#10 tom130691
tom130691
  • 147 posts
Posted 12 March 2013 - 08:50 PM
you have over steer instead with all the weight in the back :lol:
#11 Harrison541
Harrison541
    A bowl of prawns, avocado and cress?
  • 498 posts
Posted 12 March 2013 - 08:51 PM
Imagine some chav alongside you at the traffic lights in a corsa with an exhaust the size of Katie prices *ahem* thinking your car is an old banger and then you rev it and it sounds like a bike.
#12 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 12 March 2013 - 08:59 PM
Even better if you don't rev it - and vtec there ass instead :shifty:
#13 Kam
Kam
  • 4,140 posts
Posted 12 March 2013 - 09:05 PM
Where do you want the engine? front or back?
Where do you want to use it? road or track?
If you need it for the road are you liable to want to go backwards at any point - think very hard about this, its usually another sway factor if its for road use
#14 Harrison541
Harrison541
  • 498 posts
Posted 12 March 2013 - 09:15 PM
The latest pro motive gearbox has a reverse gear, I think.
But then again a VTEC engine can always be turbocharged for those times when 0-60 in 4 seconds just isn't quick enough... >_<
Edited by Harrison541, 12 March 2013 - 09:37 PM.
#15 Kam
Kam
  • 4,140 posts
Posted 12 March 2013 - 09:31 PM
The latest pro motive gearbox has a reverse gear, I think...
It has and its a good kit, I like it and nearly bought it, only downside for me was my mini wasn't gonna lose any weight so was worried about a bike lump pulling a cars weight as mentioned above by tom
There's also a point about it still looking like a mini, so where the engine is and if it fits is another factor
Z-cars kit is awesome but out of reach for most for cost and work, pro-mo kit is doable by most on both fronts, most of the issues with chains etc have been sorted, have a good read through the bike build diaries
As for vtec, well any car engine swap has its own headaches and cost and time, as for which car engine thats all down to preference - just like choosing whether to go for bike or car lump
You can revert any swap back to a-series (if it happens to happen that way) pro-mo would be alot more easier but if you took the a-series out and put a car lump in there (still FWD) then you know how to take it all back out again - its still a mini afterall
Changing back from a rear engine is a book all on its own!
