Torque Wrench
23 replies to this topic
#1 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 12 March 2013 - 01:06 PM
Hello. Is there a torque wrench which is suitable for doing most of the common service jobs on the Mini? e.g. sump plug, wheels, cooling system, maybe head gasket...
I've been shopping online for one and they all have different limitations - most of them way above what is needed for the sump plug for example which is 35Nm.
#2 cal844
cal844
  • 9,671 posts
  • Local Club: TFMOC
Posted 12 March 2013 - 01:14 PM
i usually just use a ratchet to do most jobs on mini's as there is really nothing which i cant tighten that way.
#3 Cooperman
  • 23,367 posts
Posted 12 March 2013 - 01:16 PM
To tighten all the fixings on a Mini to the recommended figures you need two torque wrenches, one going up to around 35 to 40 lb. ft, and another going from about 30 lb. ft. up to over 150 lb.ft. That way you know it's correct.
Many only use the heavier one and do the others up 'by feel/experience' which is what most professional Mini restorers do. It comes with time.
Back when the Mini was a new car it was common to change head gaskets without a torque wrench and it seemed to work OK.
But for less experienced technicians doing everything right is definately best.
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 12 March 2013 - 01:18 PM
CAL844 ???? but what about torquing the nuts to the specified figure...
I'd go for this one although its limited on the lower settings. I've actually got a couple one that does the lower range and then a big'un for hub nuts etc
http://www.halfords....tegoryId_165469
Edited by lrostoke, 12 March 2013 - 01:18 PM.
#5 lewBlew
lewBlew
  • 1,238 posts
Posted 12 March 2013 - 01:20 PM
Thanks for the info. I've got a ratchet, but also a habit of over-tightening things and don't want to do it on my sump plug!!
Would a 10-80Nm one do for sump, wheels, head gasket etc? A bit like this
http://www.ebay.co.u...=item588ec4c628
#6 cal844
cal844
  • 9,671 posts
  • Local Club: TFMOC
Posted 12 March 2013 - 01:22 PM
im in the car trade, i have a small power bar which i very rarely use (except for suspension and wheels)
#7 cal844
cal844
  • 9,671 posts
  • Local Club: TFMOC
Posted 12 March 2013 - 01:24 PM
that one would suffice mate
#8 lewBlew
lewBlew
  • 1,238 posts
Posted 12 March 2013 - 01:37 PM
Thanks everyone :D
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 March 2013 - 01:43 PM
Thats the difference between a season mechanic who has a feel for threads you know when enought is enough, and you only get that from experience, to be honest I only use the bigger one of my two torque wrenches, anything general is done by hand unless its a important like head bolts/driveshafts and so on.
Without that experience its best to have two torque wrenches and play safe.
#10 MRA
MRA
  • 7,607 posts
Posted 12 March 2013 - 03:08 PM
Maybe thats the difference between a time served aeronautical engineer wuth a MEng Degree, I use 3 torque wrenches.
A torque wrench is only good for about 80% of its range, not using a torque wrench is why when I recieve engines and transmissions (only manual) I have so many threads to restore.
I have been involved with fatigue testing of parts that are under, over and correctly torqued, I can tell you now that if you guys could see the results your torque wrenches would be out more often.
Its the same reason I refer to the manual for torque settings, its cheaper to get it right than it is to have to put it right or worse lose the customer thats been upset.
#11 firstforward
firstforward
  • 824 posts
Posted 12 March 2013 - 03:43 PM
I use one of these, accurate and easy to use.
http://www.machinema...tails/040215238
#12 lewBlew
lewBlew
  • 1,238 posts
Posted 12 March 2013 - 04:34 PM
Very swish.
#13 jackx998
jackx998
  • 264 posts
Posted 12 March 2013 - 04:38 PM
http://www.machinemart.co.uk/shop/product/details/040215238
I may just have to invest in one of those myself!
#14 Ipod
Ipod
  • 2,024 posts
Posted 12 March 2013 - 04:42 PM
Looks big for getting in those tight area's a mini has ;D
just get a clicky clicky one, unless your hard of hearing, then dont read the first part :)
#15 MRA
MRA
  • 7,607 posts
Posted 12 March 2013 - 04:46 PM
How do you know its accurate ?
Does it come with a calibration certificate ?
And if you drop it, the accuracy disapears.
Interestingly there is no tolerance data.
