Su 1.5 Service Kit?
Posted 14 March 2013 - 08:46 AM
Basically i need service my carb for a 998 which kit would I need for a hs4 and what's the best place to get it from?
Thanks Jack
Posted 14 March 2013 - 10:05 AM
Posted 14 March 2013 - 10:06 AM
Posted 14 March 2013 - 10:09 PM
Posted 14 March 2013 - 10:11 PM
Posted 14 March 2013 - 10:16 PM
Edited by KernowCooper, 14 March 2013 - 11:23 PM.
Posted 14 March 2013 - 10:48 PM
Posted 14 March 2013 - 11:09 PM
Posted 15 March 2013 - 12:37 PM
There may be a small aluminium triangular shaped tag fixed under a float chamber lid screw.It may be there, or may not be there.
Burlen fuel systems (SU) can then use that info to supply the correct kit.
A more expensive, but in my opinion, a better route might be to send them the carb and they can rebuild it for you. They did a brilliant job with mine. But that's just my approach, as I consider the carb, ie the lungs of your engine to be vitally important to get everything perfect.
If you go the kit route, and you don't have the number tag on the float chamber, remove the items which you know need replacing and you can send them to burlen and they can send you new items to the same spec. Remember, that needles, suction chamber springs can all can vary from SU carb to SU carb even though they may all be 1.5 inch carbs.
John
Edited by mk=john, 15 March 2013 - 12:52 PM.
Posted 15 March 2013 - 05:58 PM
Thanks Jack
Posted 15 March 2013 - 06:32 PM
Posted 16 March 2013 - 10:45 AM
1) Is the spindle a nice tight fit but smooth to turn ?
2) from fully closed to fully open and open to closed does it stick ?
Because if it does either of the above it will not last too long before you feel the same issues as before.
