Oil Breathing And Smell In The Cabin
11 replies to this topic
#1 Petro1head
Petro1head
  • 168 posts
  • Local Club: Cooper Register north est
Posted 14 March 2013 - 11:42 AM
Only done 100 miles on a fresh 1330 engine. I notices the cast time I was out oil dripping from the breather pipe on the timing chain cover. There is also quite a strong smell of fumes in the car
So I recon I need a catch tank. This will allow me to breath from bother the timing chain end and clutch end of the car into somit that catches the oil.
A lot of tanks seem to have a small K&N breather on them. However, and tell me if I am wrong, this will not get round the problem of the smell.
Would I be better to remove the filter and run a pipe under the car?
Does anyone have a suggestion of a suitable catch tank?
Edited by Petro1head, 14 March 2013 - 11:43 AM.
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 14 March 2013 - 12:08 PM
On the breather pipe. How have you currently got that all rigged up? To the carb or have you hooked it up else where? Also how many other breathers do you have.
On the fuel smell, you sure the tank breather pipe is connected to the top of the tank and through the hole in the floor? Cuts out a load of smell, had mine come off one or twice.
#3 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 14 March 2013 - 12:21 PM
If you want to feed it back into the carb then you don't need the breather, just run hose from all your breathers to the catch tank, then run one hose to the carb, to provide a vacuum, and help draw out the fumes from the crank case.
If you do not wish to send the fumes into your engine, then just feed them into the catch tank and fit a filter to it. If you currently have it like this then a line to a low pressure point under or to the side of the car would be your best bet I would have thought.
#4 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 14 March 2013 - 12:41 PM
Alternatively you could find out what the root cause of this issue is?
#5 Petro1head
Petro1head
  • 168 posts
Posted 14 March 2013 - 12:53 PM
I dont think there is an underlying problem, the engine is new so rings not bedded in and running 10.5:1 CR
Currently just got pipes from the breathers running in the engine bay
Fuel breather is attached and vented below the floor. However the small is not a pure petrol smell
Having spoken the Calver I do not want to breath into the carbs now
#6 Petro1head
Petro1head
  • 168 posts
Posted 14 March 2013 - 01:42 PM
Is it worse when the windows open ? If so it's the breather on the top of the petrol tank, it's blocked. Pull the pipe off the tank end and blow down it, to check.....
No, better.
Like I said, its not pure petrol smell more vaporied oil. The vent is not blocked as I have just replaced it
I was looking for idea re what people have used for beather please
#7 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 14 March 2013 - 01:43 PM
I've got a 1litre catch tank, being fed from transfer case, rocker cover and fuel pump hole (in place of timing chain cover). On the front is a small filter to allow air in, and a tiny vac pipe going into the inlet / vac side to expel the fumes. Works well.
#8 Petro1head
Petro1head
  • 168 posts
Posted 14 March 2013 - 01:58 PM
Got a photo of this and where did you get it from please
#9 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 14 March 2013 - 02:01 PM
Will get pic tonight when I am back. This is the one I have http://www.merlinmot...oduct_info.html
I had it modified to accept another inlet and the small outlet to the vac side of throttle body.
#10 Petro1head
Petro1head
  • 168 posts
Posted 14 March 2013 - 02:05 PM
#11 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 14 March 2013 - 07:41 PM
Pictures as requested:
Attached File  oil.JPG   39.41K   40 downloads
Attached File  oil1.JPG   51K   27 downloads
#12 Petro1head
Petro1head
  • 168 posts
Posted 15 March 2013 - 04:15 PM
