Just having a think about brakes for my hill climb/rally project . The back end is sorted as I have got a old set of minifins. It's the front end I have to get my head around. What I have got is a new set of 8.4 vented/grooved discs with metro calipers but I want to run 10" wheels. So could I get a way with turning the discs down to 7.9 and changing the calipers( Is the hub on a copper disc the same size as a metro hub?). If you turn it down, do you cut off all of the vented part of the disc? The next thing I have to look at is servo or not and what sort of bias braking to use?
Cheers tom
Brakes For My Hill Climb / Road Rally Mini
tom1
, Mar 14 2013 01:39 PM
2 replies to this topic
Posted 14 March 2013 - 01:39 PM
Posted 14 March 2013 - 01:47 PM
That's probably more effort than just getting a 7.9 or 7.5 brake kit. You could get KAD calipers, or minisport alloy ones they are good too
My brake set up is a late split system brake master cylinder, rears othroigh a bias valve to mini fins. Front go trough a servo to minisport 7.5 calipers. Nearly lok the fronts up on a brake roller tester without servo assistance, all the braking you need!
Posted 14 March 2013 - 07:21 PM
hi, i have a hill climbing mini, i would recommend running KAD brakes on the front, great stopping power and very well made.
