Brake Fittings Thread Size
9 replies to this topic
#1 bartman
bartman
  • 265 posts
Posted 14 March 2013 - 06:31 PM
hi i am replacing all my brake lines with braided ptfe lines i need to know what the thread sizes are for the rear brake cylinders the brake pressure regulator valve, as i need to get the right adapters for the hose ends
#2 scott_65_cooper_s
scott_65_cooper_s
  • 104 posts
  • Local Club: open to suggestions
Posted 14 March 2013 - 06:39 PM
I think you'll find they are 3/8" UNF I made internal lines for mine with that size and the standard/non-standard all went together with no leaks.
#3 A-Cell
A-Cell
  • 1,610 posts
Posted 14 March 2013 - 06:42 PM
Yep I reckon they are 3/8" UNF
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 14 March 2013 - 06:49 PM
The master cylinder/servo and ghastly taper nose 'pressure regulator' are M10 X 1
#5 scott_65_cooper_s
scott_65_cooper_s
  • 104 posts
Posted 14 March 2013 - 06:52 PM
Incidentally, personal choice, on my mk1 which has a single line system, I sacked off the rear subby bias as I made my own lines too. Replaced it with a std T piece then ran the front to back line along the top of the tunnel inside the car. I then fitted an inline adjustable bias which I mounted to the top of the cross member between the hand brake & gear lever.
#6 R1minimagic
R1minimagic
  • 4,660 posts
Posted 14 March 2013 - 06:54 PM
Why are you replacing them with these? Better off with solid lines
#7 MRA
MRA
  • 7,607 posts
Posted 14 March 2013 - 09:06 PM
And you may also find M11 x 1 as well.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 14 March 2013 - 10:30 PM
And if you have the yellow tag master cylinder the top outlet one is 10mm and the bottom one 12mm
#9 MRA
MRA
  • 7,607 posts
Posted 14 March 2013 - 10:42 PM
Well done Dave, my post should have read M12 x 1mm sorry :-( I don't know why I put M11, as I just bought 100 M12 flare nuts :D
#10 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 14 March 2013 - 11:29 PM
I did think M11 but as you learn something every day in this game I thought ok M11s out there as well
