Weber Carb
9 replies to this topic
#1 D_Allen
D_Allen
    Starting My Mini Up
  • 2 posts
Posted 15 March 2013 - 03:06 PM
just got this weber carb and i was wondering if anyone could help me identify it and weather it would suit my car. there is no model number on it that i can find at all
http://oi50.tinypic.com/jhx5hz.jpg
http://oi47.tinypic.com/jiz2xi.jpg
http://oi46.tinypic.com/2mooy7r.jpg
http://oi50.tinypic.com/2eq7t3t.jpg
any help at all would be appretiated
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 March 2013 - 04:59 PM
Its a Weber 28/36 and is used and rated by Vizard in the yellow bible, I used to run one on a 998 Cooper a few years back and it works quite well once correctly jetted, What size is your engine? if its a Std 1275 or less then it would be suitable, if you have a modded 1275+ you'll get more performance from a HIF44
#3 Cooperman
  • 23,371 posts
Posted 15 March 2013 - 05:25 PM
Mark, what inlet manifold did you use with the 28/36 Weber? I must say the 28/36 was a great carb on the old Cortina GT and should also be good on the Mini so long as the manifold is well-designed. I know when I changed from a 28/36 to twin 40DCOE's on my old Mk.1 GT there was an improvement, but not as much as I expected even though I had a Cosworth A2 cam and a 'works' rally head. It used a hell of a lot more petrol with the twin 40's though!
#4 D_Allen
D_Allen
    Starting My Mini Up
  • 2 posts
Posted 15 March 2013 - 05:38 PM
just got a 998 so it sounds like it will be good. but thanks everyone been a gret help. couldnt find any info about it at all.
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 March 2013 - 05:40 PM
Yes I have tried it and not going by the book, the 28/36 with 26/27mm chokes flows 225cfm and a Hif44 flows 240cfm, and as you know cfm depends a lot on the cylinder head/valves and its restrictions and the type of manifold fitted. My 998 Cooper was better on the 28/36 than the 1292, but the Cooper was standrd and HS2s The 1293 modified.didnt and I changed to a 45DCOE.
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 March 2013 - 05:41 PM
Should work very well on the 998 engine when jetted correctly.
#7 Cooperman
  • 23,371 posts
Posted 15 March 2013 - 05:48 PM
I've asked Mark what manifold he used with his 28/36.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 March 2013 - 06:02 PM
I understand that there were several verions of the 28/36 manifold available at the time, and the one in the photos in D Allen post was with the carb facing the correct way to produce power, the other manifolds put the float chamber on the n/s which could cause fuel surge and one other had the manifold setup in relation to the chokes.and needed modifying internally to increase its cfm
Mine was as per D Allens.
Edited by KernowCooper, 15 March 2013 - 06:03 PM.
#9 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Posted 15 March 2013 - 06:14 PM
Make sure it's jetted correctly mine isn't and is quite a nightmare worth doing it properly as the previous owner didnt :L
#10 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 March 2013 - 06:17 PM
you can get all the bits for rejetting or rebuilding from eurocarb
