Which Sills?
Posted 15 March 2013 - 07:33 PM
thanks
will
Posted 15 March 2013 - 07:37 PM
http://www.minisport...40_12_00_3.html
http://www.minisport...40_12_00_4.html
or the genuine ones:
http://www.minisport...fo_14A9534.html
http://www.minisport...fo_14A9535.html
thanks,
Adam
Posted 15 March 2013 - 07:38 PM
Posted 15 March 2013 - 07:43 PM
why do you think they;re not correct after buying them?? surely the question should have been asked before...
hi, i think he must have bought the 4.5" sills thinking there were the original ones for his car but realised they weren't after buying them
thanks
Edited by strettman, 15 March 2013 - 07:43 PM.
Posted 15 March 2013 - 07:48 PM
Posted 15 March 2013 - 08:09 PM
Posted 15 March 2013 - 08:10 PM
What made me question myself is that it had oversills on which were far wider than the new ones. is it correct that the little corrugations are left open?
yep!
Posted 15 March 2013 - 08:26 PM
cheers guys. Is that why the oversills rot so bad because the flutes are closed?
Posted 15 March 2013 - 08:28 PM
Goooooood! looks like accidentally on purpose I've got teh right ones after all!
Yes that's part of it but the real issue was they were normally welded over the old rotten sill so just sandwiching the rust and causing more destruction.
Posted 15 March 2013 - 08:40 PM
Posted 15 March 2013 - 08:45 PM
trapping moisture and salt ect so just a rusty accident waiting to happen?
Basically yes. The ones on Paddy were not fitted really well but at least the old ones were off. If they had added some waxoyl then there would have been minimal rusting if any.
Posted 16 March 2013 - 10:57 AM
Both of them are useless, because the welds on the lower edge will not be in the correct place to form a proper box section of adequate stiffness. It should be illegal to sell such things, which have no possible safe and legal use.
If you have a 6" or 9" sill, and it is the correct 0.9mm thickness (some cowboy bodger's parts are dangerously thinner), the best thing to do with it is to cut it down to the correct width before fitting it, or send it back for a refund because it is not fit for purpose.
