Pulls To The Left
Posted 15 March 2013 - 09:12 PM
Posted 15 March 2013 - 09:23 PM
Posted 15 March 2013 - 09:27 PM
Posted 15 March 2013 - 09:28 PM
Posted 15 March 2013 - 09:49 PM
Edited by a_woolhouse, 15 March 2013 - 09:51 PM.
Posted 15 March 2013 - 09:50 PM
Posted 15 March 2013 - 09:51 PM
Posted 15 March 2013 - 09:54 PM
Are you on front discs or drums
Edited by KernowCooper, 15 March 2013 - 09:57 PM.
Posted 15 March 2013 - 10:25 PM
Not condition you can have good discs and new pads/ shoes/drums if the caliper Pistonss/cylinders are tight the more efficient brake in your case the left will make the car pull to the left. If it pulled left under normal driving that a different thing, look at the right side caliper pistons/cylinders and thats where the problem will lie.
I'm on discs
Posted 15 March 2013 - 10:42 PM
Check to see how full the brake master cylinder is as if its full pushing the pistons back may overfill the plastic tank and shoot fluid out the air hole If the pistons are tight or siezed ( you should be able to push them back in quite easily with a lever ) then its time to get a seal overhaul kit and strip/clean and replace the seals.
Edited by KernowCooper, 16 March 2013 - 11:29 AM.
Posted 16 March 2013 - 10:49 AM
Edit: The error in above post is now corrected.
Edited by tiger99, 16 March 2013 - 11:32 AM.
Posted 16 March 2013 - 11:21 AM
Clutch master cylinder? Unless you have very odd (and completely illegal) plumbing, it will be the BRAKE master cylinder!
What could be up with the master cylinder then?
Posted 16 March 2013 - 11:23 AM
Posted 16 March 2013 - 11:29 AM
Posted 16 March 2013 - 12:53 PM
