Cam Fitting?
4 replies to this topic
#1 Craig914
Craig914
  • 116 posts
  • Local Club: Wirral Minis
Posted 16 March 2013 - 02:17 PM
Just wondering if my engine will need to come out to fit my hi lift cams?
My car is a;
1993
1275
Rover rio
I've watched rebuilds on youtube & it looks like some are overhead cam and others are centred
Thanks for any answers
#2 holmesy
holmesy
  • 879 posts
Posted 16 March 2013 - 02:21 PM
yes the engine will need to come out, why you have cams i dont know :P but to fit just one in then yes it needs to come out
#3 james.c94
james.c94
  • 164 posts
The a series will always be a push rod engine unless its got a BMW head on it. With a 1275 you'll need to take the engine out otherwise the followers will fall straight out. Some will say that you need to split the gearbox and crank cases but you can actually just sit the block on its face when putting the cam in.
#4 MRA
MRA
  • 7,607 posts
Posted 16 March 2013 - 02:48 PM
It could have a JOMO overhead cam cylinder head or a JKD or KAD 16v twin overhead cylinder head in either case including the BMW conversion the engine would not need to be removedto swap camshaft/s
#5 MRA
MRA
  • 7,607 posts
Posted 16 March 2013 - 02:55 PM
It is generally recognised that to do the job properly you need to strip the engine fully and also replace the followers, the new camshaft and old followers will never last long.
Also to avoid damage to the bearings the camshaft must be lowered without touching the cam lobes against the bearing surface.
