Intermittent Power Loss
Posted 19 March 2013 - 05:57 PM
This time last week and again today I noticed a gradual loss of power, but after a few minutes of waiting at the side of the road the car seemed to have cured itself and was running fine again.
I was travelling at a fairly constant 30 in fourth in both instances, noticed a slight deceleration, so changed down to third, but from there it slowed down almost to the point of stopping completely.
In between these two events it has covered many miles without a problem.
When it happened the second time I put the choke to full, although it made no difference and the guage indicated that it was running at normal temperature.
Throughout the engine sounded fine, just like it was under a very heavy load or that the brakes were sticking.
My suspicions include ignition and vacuum advance although I would be very grateful for any suggestions as I don't really know where to look for this fault.
Nick.
Posted 19 March 2013 - 06:07 PM
Posted 19 March 2013 - 06:45 PM
Thanks for all the advice
Nick
Posted 19 March 2013 - 06:48 PM
The HT leads have been replaced very recently and the engine didn't misfire, so It probably wasn't that. Next time it happens I will check the wheels in case it is the brakes. Another suggestion I have been given is that there are bits in the fuel bowl that blocked the jet and when I stopped they fell back to the bottom as there was little suction, which would explain how the fault seemed to cure itself. Any opinions as to the validity of this suggestion? I intend to check the fuel bowl tomorrow but I am doubtful that that is the sole cause of the problem.
Nick
Could well be fuel related as you said or a faulty pump?
Posted 19 March 2013 - 07:07 PM
Posted 19 March 2013 - 07:42 PM
You don't have a vacuum in the tank building up do you, when it dies away remove fuel cap big rush of air means air vent is blocked
Posted 19 March 2013 - 07:51 PM
Posted 19 March 2013 - 08:49 PM
