Help Diagnose My Problems!
Posted 19 March 2013 - 06:52 PM
i have a 88 austin with 998 engine
the problem is that when i drive the car and i step on the accelerator it starts to gag ! (dead spots) but these doest have when i go slow or when i dont spet to much on the gas.
here are two videos i dont know if they help
one is the sound of the engine i dont know if its a misfire ? (exhaust sound)
the other one is too see if you can hear from inside the car while the gaging happens
Posted 19 March 2013 - 06:53 PM
Posted 19 March 2013 - 07:25 PM
If not it sounds like some sort of fueling issue.
Edited by Orange-Phantom, 19 March 2013 - 07:29 PM.
Posted 19 March 2013 - 07:31 PM
Posted 19 March 2013 - 07:58 PM
Have you checked firstly for water in distributor?
there is no water in the distributor
what could be the problem with the fuel ? fuel pump? carb?
Posted 19 March 2013 - 08:04 PM
Have you carried out a basic engine? Points/ Condenser Timing and tappets, hard to see in the video but appears the tacho is dropping when it falters indicating its a ignition symptom.
yeah its a basic engine no mods/ if i replace the points i need to adjust the new ones right ?
Posted 19 March 2013 - 09:18 PM
Posted 19 March 2013 - 09:45 PM
how can i check the timing ?
sorry for the ignorant questions im new with mini
Posted 19 March 2013 - 10:05 PM
1978-on 998cc is 8degs BTDC at 1000 rpm with the vacuum pipe disconnected, (blank vac pipe to ensure smooth idle)
Posted 19 March 2013 - 10:11 PM
i have another question for you.. i mounted my new set of points in, do i just set it to 0.015" ? or do i new to rotate the engine ? or what should i do ?
Posted 19 March 2013 - 10:13 PM
Posted 19 March 2013 - 10:14 PM
Posted 19 March 2013 - 10:34 PM
Posted 19 March 2013 - 10:40 PM
Posted 22 March 2013 - 03:37 PM
the rpms dont go down when it gags
i tock it to a mechanic and he said the the shaft in the distributor has a lot of play from rotating (it should have that right? )
i will take video in a little
what else can be the problem ?
