Help Diagnose My Problems!
17 replies to this topic
#16 zuluaga63
zuluaga63
  • 113 posts
Posted 22 March 2013 - 03:38 PM
i forgot to mention that when it is in neutral i can rev it and it doesn't gag so its only when the car is moving
#17 zuluaga63
zuluaga63
  • 113 posts
Posted 23 March 2013 - 11:45 AM
has any one had this problem before? can someone help me out im frustrated
#18 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 March 2013 - 01:03 PM
Once the ignition components have been checked and confirmed they are ok, plugs and points you've done get the timing checked and do the valve clearances, now you have to start to look at the fuel system,
Does the fuel pump deliver the right quantity of fuel or is the pump faulty, do you have the breather choked in the tank causing a vacuum? is the slide in the carb operating correctly, lift up and does it fall back with out jamming? is there oil in the carb damper, do you have dirt in the fuel causing a blockage in the carb? Its a process of fault finding and working your way through it all.
With it running squirt some WD40 around the inlet manifold gasket and the gaskets on the carb, does it rev up indicating a air leak on the gasket?
Depends if you have the mechanical knowledge to remove the carb if its a HIF Type? or a HS its easier to look in the float bowl for dirt.
There will always be a limit with out the basic skills to diagnose faults, do you have any mates in the Motor Trade who could help you out?
What you have to remember is that the symptom you have could be caused by a number of faults and you cant just pick one out and say thats caused by this or that, its a process of elimination unless the problem is staring you in the face like the carb is loose and hanging off and sucking air.
Have a run through the above and see what that turns up
Edited by KernowCooper, 23 March 2013 - 01:08 PM.
