Spot Welding
7 replies to this topic
#1 rodandtom
rodandtom
  • 998 posts
Posted 20 March 2013 - 08:25 PM
Hi
I am trying to get the settings right on my Clarke 151 EN Turbo too do spot welding. I've punched holes in some 0.8 mm but I can't get the settings right. Anyone got any tips? If I have the settings low then it doesn't penetrate. Too high and it still doesn't seem to penetrate but it blows the top sheet away. There has got to be a way of working out the right settings.
Thanks,
RodAndTom
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 20 March 2013 - 08:35 PM
0.6mm wire settings is whatever sounds best..least thats how I work, if it sounds right it normally is.
use short bursts don't hold trigger to longer..
The manual suggests for thickness 0.6 - 0.8 A 2 Min for 0.6 wire
0.8 - 1.0 ....... 1 2/3 max
#3 rodandtom
rodandtom
  • 998 posts
Posted 20 March 2013 - 08:43 PM
Ok I should have mentioned I have .9 cored wire. How much will that hangs those settings do you think?
Just read the post properly. I will give that a go and get some practice in ;-)
Edited by rodandtom, 20 March 2013 - 08:44 PM.
#4 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 20 March 2013 - 09:03 PM
Just to note, this is plug welding, not spot welding
#5 rodandtom
rodandtom
  • 998 posts
Posted 20 March 2013 - 09:10 PM
Fair enough. Plug, spot or anything else - I can't do it properly right now :-)
One of my mates reckoned that you should drill right through both pieces of metal and the seal the edges together with the weld. That doesn't sound right so am I doing it right by only punching one piece of metal?
Edited by rodandtom, 20 March 2013 - 09:11 PM.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 20 March 2013 - 09:21 PM
Yes you are right one layer only. With a 1/4" hole I use max power on my 135 and wire speed to 8.
#7 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 20 March 2013 - 09:26 PM
Make sure the panels are clamped together tight, otherwise you are much more likely to blow holes
#8 biker1981
biker1981
  • Just Joined
  • 303 posts
Posted 23 March 2013 - 09:04 PM
get some squashed copper pipe and put it on the other side of the hole, as the weld doesnt stick to the copper just a little easier to fill the hole.
