I Have Searched But I Still Need Help With Gauges
Posted 20 March 2013 - 11:44 PM
How are we all doing? Basically i have been wondering why my fuel and temperature gauges aren't working? All the others are woo! I have searched on here and discovered that connecting the 2 wires that connect to the fuel tank should register a full tank so when I got home I tried this and it worked got a full tank whilst I was there I changed the spade connectors and cleaned the connector I then thought I'd have a look at the cable below the thermostat housing the connector was corroded as was the spade so I cleaned the connector and replaced the spade however neither of them are working still and I have also read that this could be the voltage stabiliser but I can't find this and so I'm beginning to wonder how I go about fixing it? If anyone has any input that would be marvellous!!
I pretty sure (although don't quote me that my dials are like these http://www.theminifo...on#entry1435440 but my ones also include a rev counter which is also working hehe
Thanks guys!
Jonny
Posted 21 March 2013 - 12:01 AM
Posted 21 March 2013 - 09:39 AM
thanks in advance!
Jonny
Posted 21 March 2013 - 09:56 AM
Does the temperature gauge respond if you earth its sender cable too?
Edited by Dan, 21 March 2013 - 10:07 AM.
Posted 21 March 2013 - 01:11 PM
Sorry i'm retarded!
Jonny
Posted 21 March 2013 - 11:40 PM
Posted 22 March 2013 - 12:12 AM
Nippon Seiki Stabilizer
However, you said that connecting the two sending unit wires at the fuel tank DID make the fuel gauge go to full. That means the stabilizer is probably OK and that the issue/fault is the fuel sending unit in the tank.
To test the temperature sending unit you do almost the same test. You disconnect that green/blue wire from the temperature sender on the cylinder head and earth the connector on the wire while the ignition is on. After a minute the temp gauge should climb to full if the stabilizer and gauge are working and the wiring is intact.
Posted 22 March 2013 - 08:32 AM
Thanks so much for you help guys your all stars!!!!!!!
Jonny
Posted 22 March 2013 - 09:27 AM
Posted 22 March 2013 - 11:49 AM
Ok sorry to be stupid but which wire should i use from the ignition? im not much cop with electrics lol! a color would be handy if possible?!
Sorry, I don't understand your question. I didn't mention any ignition wires so I don't know how to respond.
Above Carlos is telling you how to test the temperature gauge (as did I). Give that a try and let us know what the temperature gauge does.
Posted 22 March 2013 - 11:57 AM
I didn't understand either so I thought I'd reiterate what you said! I did this on Saturday and successfully diagnosed a faulty temp sensor
Posted 22 March 2013 - 01:07 PM
Sorry my bad i read it all wrong! il try it when i get home!!
Thanks guys!!
Jon
Posted 22 March 2013 - 01:14 PM
i need these bits by tomorrow will i be able to get them anywhere in essex?!
Jon
Posted 22 March 2013 - 06:02 PM
Thanks so so much guys were getting there! Sorry im a noob!
Jonny
Posted 23 March 2013 - 02:02 PM
Jonny
