Which Valve Guides And Springs For 12G295 Head
4 replies to this topic
#1 Patriot
Patriot
  • 125 posts
Posted 21 March 2013 - 10:49 PM
Hi,
could anyone let me know what size and type valve guides to install in a 12g295 head.
Also,
what is the best spring set to buy.
many thanks
#2 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 21 March 2013 - 11:01 PM
Standard cast iron valve guides are fine, there's only one size bar turbo spec
There many different ''best'' valve springs for different applications - e.g. standard springs are best for a standard engine. Don't just put the strongest springs you can find, the extra unecessairy pressure needlessly saps power and increases cam and follower wear
#3 Cooperman
  • 23,315 posts
Posted 21 March 2013 - 11:54 PM
Valve guides are either cast iron or some sort of manganese-bronze alloy. IMHO the cast iron are best as there have been some valve sticking with manganese bronze. Now, as to valve springs, that will depend on the cam chosen and hence its optimum operating revs. You need to get the recommended valve spring data from the cam manufacturer, then set them to the correct fitted length.
#4 Patriot
Patriot
  • 125 posts
Posted 22 March 2013 - 07:35 AM
many thanks
#5 MRA
MRA
  • 7,607 posts
Posted 24 March 2013 - 12:25 PM
Sticky valve guides are normally due to incompatible valve stem materials.
The A series has been fitted with many different valve guides over the years, as above the ones that will not be compatible are the turbo exhaust valve guides.
The main differences are in the application, the "nose" shape, length (ie diesel A Series are very long about 2.25") stem seal grooves, as the very early ones didn't have these.
