Floor Gap Help
3 replies to this topic
#1 billok
billok
  • 228 posts
Posted 22 March 2013 - 09:13 PM
i am fitting a new floor to my mini 25 but the floor won't line up with the rear bins please if someone could advise how i can close the gap? or it it is all right to be a gap?
thanks in advance
#2 1984mini25
1984mini25
  • 8,843 posts
Posted 29 March 2013 - 11:07 PM
I’d tack every inch or so along the floor if that section of the repair lines up and then carefully using a jack/wood from underneath to close up the gap. Then if the inner sill now sits higher than the door step flange, which it probably will, trim it back so it’s flush before welding.
Or tack the floor as before and along the doorstep flange and using a length of wood or similar gently hammer the flange down to meet the floor from the inside of the rear bin. Or maybe a combination of both of the above.
#3 billok
billok
  • 228 posts
Posted 30 March 2013 - 12:54 PM
thanks going to give it a go tomorrow so i will see how it goes
#4 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 30 March 2013 - 04:02 PM
yuck bodge repair dont weld up the bin, and make floor repair panel fit where rust holes are :)
