I have a 92 mini city which has the 2 dial speedo the speedo light up which come on when you turn your car light on will not come on but the car lights are . Any ideas ???
Speedo Light Not Working ?
sam138
, Mar 23 2013 08:16 AM
5 replies to this topic
Posted 23 March 2013 - 08:16 AM
Posted 23 March 2013 - 08:48 AM
Cant quite understand what you have written but maybe a it needs a new bulb in the clocks?
Posted 23 March 2013 - 08:49 AM
Just the speedo? Does the fuel / temperature gauge light up?
Posted 23 March 2013 - 09:12 AM
So not very clear the whole unit does not light up have checked all fuses and they are fine the 4 in the bulkhead box . Do minispares sell all the bulbs or is it a problem with something else as one of my rear tail light has stop working and front lights only when lights are switched once down . Take it this is dipped beam .
Posted 23 March 2013 - 09:57 AM
You could try taking the dails off and cleaning the connections where the bulb holders twist into place on the PCB. I've got a 92 cooper and my dials weren't lighting up.
Posted 23 March 2013 - 11:03 AM
This is not dipped beam it is the side light circuit. If the whole cluster has stopped lighting up I would imagine the problem is at the panel connector.
