Replacing Mk4 Dash Switches Via Mk1
Posted 23 March 2013 - 12:50 PM
Posted 23 March 2013 - 12:58 PM
step 1) remove everything in the area i.e switch panel,dash rails ect..
step 2) Weld a sheet of metal in the switch hole to create a blank canvas to work from.
step 3) cut out to size & buy these parts: http://www.minisport...fo_14E3386.html http://www.minisport...fo_14A7172.html
step 4) re-fit up the choke & heater control then deal with the electrical jargen as you wish (not my area of knowledge electrics haha)
*thumbs up*
Posted 23 March 2013 - 02:39 PM
Posted 23 March 2013 - 07:51 PM
Posted 23 March 2013 - 08:02 PM
Posted 23 March 2013 - 08:11 PM
The first post I ever made here in fact was a complete list of all the toggle switches needed to replace the late Mini rockers (Delta I think the range is called) with specific switches to avoid needing loads of relays to do the job.
Posted 23 March 2013 - 08:17 PM
You should be aware that as of last Wednesday the brake test switch is an MOT item. You can make a suitable replacement from any warning lamp and a toggle type test switch that will blend in.
Didn't know that Dan. What if your car didn't have one?
Ian
Posted 23 March 2013 - 08:21 PM
Posted 23 March 2013 - 08:28 PM
If it didn't have one when it was made then it'll be fine, I'm not sure what year the brake warning lamp became a requirement but that will be the same for the MOT as it was for Construction and Use Regulations. If you mean that the car didn't have one when you got it because the previous owner removed it then I would suggest you will have to refit one.
It's amazing what you can learn here, the info about the new MOT came from Samsfern the other day.
Posted 23 March 2013 - 08:37 PM
I had better look into this, my MoT is next month.
You might have saved me a retest, so thank you. :)
Ian
Posted 24 March 2013 - 11:03 AM
Posted 24 March 2013 - 11:11 AM
