Torque Wrench And Ball Joint Spliter
10 replies to this topic
#1 Jayme 1275
Jayme 1275
  • 488 posts
Posted 23 March 2013 - 03:47 PM
Hi guys
Have to replace the wheel bearings in my car this year and going to be carrying out some other work so thought it may be a good time to invest in a Torque wrench, nothing insane im not going to be building racing engines. anyone any recommendations
and also gonna need a ball joint spliter anyone bought one they think is good and easy to use?
#2 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Posted 23 March 2013 - 03:51 PM
Teng Torque Wrenches are good, or the Halfords advanced professional range.
#3 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 23 March 2013 - 04:10 PM
the halfords scissor ball joint splitter is good, or the drapper one isn't much more expensive, just make sure you get a scissor type one, anything else is useless
#4 jsiggee
jsiggee
  • 383 posts
Posted 23 March 2013 - 04:11 PM
torque wrench id either go for sealey or williams, you will need one which goes up to and beyond 200lb/f i think if youre doing wheel bearings, as for the splitter the easiest ones to use are the ones with a bolt which you tighten to split the ball joint the ones you just hammer in are a lot harder to use and you risk damaging bodywork ;)
#5 firstforward
firstforward
  • 824 posts
Posted 23 March 2013 - 04:15 PM
I highly recommend one of these............
http://www.machinema...TC=RV-040215238
#6 mini*mad
mini*mad
  • 423 posts
Posted 23 March 2013 - 04:25 PM
Couldnt find my ball joint splitter the other day, and had to remove both front hubs!
a little trick that works is to give the arm connected to the ball joint a sharp tap with a hammer and it comes off easily :)
May want to give that a go as it worked for both sides!
#7 Noah
Noah
  • 4,136 posts
Posted 23 March 2013 - 04:27 PM
I generally use the 'thwack with a hammer route' use a cooper/hide hammer and you won't do any damage to the hub.
Hit what it goes through.
#8 Jayme 1275
Jayme 1275
  • 488 posts
Posted 23 March 2013 - 04:39 PM
Thanks guys appreciate it.
#9 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 23 March 2013 - 04:41 PM
That looks rather good, you have one yourself? :D
#10 firstforward
firstforward
  • 824 posts
Posted 23 March 2013 - 04:45 PM
Yes I posted some info on it here..... http://www.theminifo...ch/page__st__15
#11 Ryang556
Ryang556
  • 2,747 posts
Posted 23 March 2013 - 05:06 PM
May have to invest in one of these... :shifty:
