Rockers And Valve Spring Question. 12G202 To 12G295
Posted 23 March 2013 - 10:43 PM
just bought a 12g295 head to replace my 12g202 on my 1098, will the rockers and valve springs simply transfer over as the 12g295 head only comes with valves.
thanks
Posted 23 March 2013 - 10:53 PM
The valve springs & rocker shaft should be interchangeable between those 2 heads. However, if you are fitting or do ever fit a different cam you would need to check which valve springs are recommended by the cam manufacturer and then set the correct springs to the recommended fitted length.
Posted 23 March 2013 - 10:58 PM
Posted 23 March 2013 - 11:00 PM
thanks, changing cam in the summer.
You will probably need to change the valve springs then unless you already have the recommended springs. Which cam are you going to install if you don't mind my asking?
Edited by Cooperman, 23 March 2013 - 11:00 PM.
As a matter of course how old are your current springs in terms of mileage, if they have covered lots of mileage I'd replace them while you have it apart
Just read your update, new springs now a good idea, depending on the cam even double springs as per the original spec on the 12G295, even though the 1098 is not such a high reving as the 998.
Edited by KernowCooper, 23 March 2013 - 11:03 PM.
Posted 23 March 2013 - 11:10 PM
thanks
Posted 23 March 2013 - 11:18 PM
Posted 23 March 2013 - 11:19 PM
Posted 23 March 2013 - 11:45 PM
Posted 23 March 2013 - 11:55 PM
I had a MG 1100 engine is a mini a few years back and it went very well.
So did I. It was an MG1100 unit with a 295 gas-flowed head, a 731 cam and a full 998-type exhaust.
